DAB Hi-Fi question
Discussion in 'Hi-Fi Stereo Systems & Separates' started by mel769, Feb 12, 2018.
  1. mel769
    mel769
    Feb 12, 2018
    25
    London
    Hello there, hope someone can help; ve just joined this forum and after some advice. Im looking at buying a second hand DAB Hi fi system thats about 10 years old, Ive been looking at the TEAC DR-H300. My question is would this old DAB hi-fi be able to scan and pick up the most recent channels??
    Ive read somewhere that older DAB systems can get some stations, but not some recent ones cause they are on a different wavelength (or whatever). Is this true ??
    Thanks a million for any answers
  2. Sonic67
    Sonic67
    Sep 14, 2006
    43,858
    11
    167
    Home
    +22,001
    It might be it gets DAB but not DAB+. DAB+ uses a smarter compression system. Essentially it means you might miss out on some radio stations.
  3. mel769
    mel769
    Feb 12, 2018
    25
    London
    Great thanks for info,
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,965
    +7,169
    But the number of stations broadcasting in DAB+ is tiny & there are no plans for wholesale switching.
  5. Ned Senior
    Ned Senior
    Aug 14, 2006
    4,818
    Stalag 9
    +1,165
    Is the dab sound quality better say than tunein internet radio????
    Or would the freeview radio stations be better via tv????
    I used to like the V tuner app on samsung tv but it is not currently working
    (Sorry for the thread intrusion but its actually about DAB as I was toying with the idea ofgetting a tuner)
  6. BlueWizard
    BlueWizard
    Jun 19, 2007
    21,986
    +4,128
    Curious how much money you have to spend?
    There are Tuners that have DAB and DAB+.
    Also, are you looking for a small tabletop portable Radio, a self-contained device, or are you looking for a Tuner to add to an existing system?
    Steve/bluewizard
  7. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,965
    +7,169
    Both are likely to be better than DAB.
    • Agree Agree x 2
    • Like Like x 1
    • List
  8. Ned Senior
    Ned Senior
    Aug 14, 2006
    4,818
    Stalag 9
    +1,165
    Thanks Croc
  9. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,965
    +7,169
  10. simon194
    simon194
    Nov 29, 2006
    1,779
    63
    +215
    Usually the internet radio stream will be the stereo stream provided by the broadcaster which is an improvement over DAB since most music stations on DAB are now mono. I've noticed recently that Tunein are starting to use the mono stream that is broadcast on DAB.
