dab do i need an ariel
Discussion in 'Music Streamers' started by bobone, Jun 4, 2005.
  1. bobone
    bobone
    i am buying a teac crh250 mini system will i need an outdoor/indoor ariel and if so can anyone recommend one thanks
  2. bobone
    bobone
    i am buying a teac crh250 all in one system with dab will i need an ariel indoor/outdoor and if so can anyone recommend one also has anyone had experience of sonance ceiling speakers which i am going to use with it thanks bob
  3. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Any radio tuner, be it FM or DAB will greatly benefit from an outdoor ariel - well worth the investment.
    What type of ariel depends on where you are located and what the reception is like. I am lucky enough to live in an area with good reception and always used an omni-directional ariel with my FM tuner (an onmi-directional ariel is a circular ariel that picks up signals from all directions, rather that a directional ariel that tends to be pointed at one transmitter).
    When I switched over to a DAB tuner, I enquired of a couple of ariel installers whether I would need a special ariel for digital reception. Both said yes. Before taking the plunge I tried my existing ariel and the readout on the tuner shows I am achieving maximum signal strength through the existing FM ariel.
    So don't let them con you into buying another ariel that you don't need. Provided your area is covered by a DAB multiplex you can receive digital broadcasts. If FM reception is good in that area then your existing FM ariel will suffice for DAB.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Take a look here
    If you are in one of the "pink" areas, you will probably get away with an indoor aerial. Otherwise, you can get one from Maplin Electronics
  5. simon100
    simon100
    Nov 2, 2004
    318
    +11
    I have this Dab receiver and am very happy with it. I am using the supplied ariel and picking up a good signal in Stockport.
    However you need to experiment as to the best place for it as a couple of cm's either way can make all the difference.
  6. bobone
    bobone
    my area looks very pink cheers
  7. penumbra
    penumbra
    Jun 6, 2005
    61
    rye east sussex
    +3
    Hi, i installed some sonance cieling spkrs. for a client a few years ago, these were 2 way with adjustable tweeters and had adjustable responce via dip switches, i also installed the sonance flush cieling SUB!.
    Great sound, not as lean as B+W or Kef (which i think were technically more accurate) but more enjoyable IMO.
    if you must have cieling spkrs. they are certainly worth a listen, bear in mind they will sound Very different in your cieling then when mounted on a baffle in a shop.(the diff is Much bigger than normal spks.)
    Jaz
