DAB available in AVR300
Discussion in 'AV Receivers & Amplifiers' started by bluesfan, Dec 26, 2004.
Tags:
  1. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    Mr Dawson,
    Can Arcam consider fitting a DAB radio in the AVR250/300?
    It's a bit much in this day and age that only FM radio is available!
    If they don't won't to go the whole way can't they provide it as an option?
  2. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I think the reason you won't see that is that Arcam produces the same unit for worldwide distribution, only changing the power and AM step settings for particular locales. DAB, on the other hand, is not available worldwide. For us US customers it would just be wasted money to have it. And if Arcam were to produce locale specific options it would just increase manufacturing costs and thus raise the cost to us.
    Best bet is to get an outboard DAB and connect it to an available input.
  3. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    Don't agree at all. I'm sure a card option can be made available at minimal cost to Arcam and reasonable profit (like the 7.1 card).
    Most countries now want to switch off analogue transmissions as they interfere with their ability to offer digital services. In the UK this has delayed the implementation of digital tv and radio in many areas because turning on digital would interfere with analogue transmission.
    There is no way that analogue will be switched off as long as people like Arcam continue to stick fm radios in hifi.
  4. dml
    dml
    Personally I'd like to see an AVA300, ie an amplifier not a receiver.
    Any chance?
  5. SMCC
    SMCC
    How about an AVP300 - i.e. no amps, just a processor? It would go very nicely with my A85/P85's.
  6. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I'd also like to see a Pre/Pro somewhere between the AVR300 and the AV8 as I rarely use the AM/FM tuner and now use Alpha amps instead of the 300 amp section. The DIVA AV80!
