New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Living in Whitley Bay NE25 9AX DAB reception is week.
I intend to install a antenna on my roof to enjoy my DAB radio, where can I obtain information on the direction I should point my anntenna.
What stations do you want to listen to?
If it's the national ones, then a non-directional aerial may be best, as it recevies from all in-range transmtters at the same time. With DAB ( unlike analogue radio ), the signals add together constructively.
I stuck my aerial in the loft. I then attached a short co-ax and a portable DAB radio. I turned the aerial various directions and used the auto-tune and the radios signal strength meter to get the best direction.
