DAB and line in from mp3 for car radio
Discussion in 'Music Streamers' started by Simmo81, Mar 23, 2006.
  1. Simmo81
    Simmo81
    Nov 28, 2004
    151
    Scunthorpe
    +17
    Has anyone used this
    http://www.argos.co.uk/webapp/wcs/s...&catalogId=4501&langId=-1&searchTerms=5004159
    product code 5004159 in argos £99.99
    It converts your car radio into a DAB radio apparantly. But in the catalogue it also says it accepts line in input from any source such as an mp3 player. My question is how is it installed (it says free installation in the catalogue) who does Argos get to install it for you? I wouldnt want it hanging from my windcreen though, do you think it will install anywhere else?
    It just seems that I would be able to use this as a DAB radio as well as putting my mp3 player through it, instead of getting an FM transmitter, just for my mp3 player.
    anyone seen anything similar?
  2. simon100
    simon100
    Nov 2, 2004
    319
    +11
    Revo do something similar.
    Try this link:
    http://www.revo.co.uk/index.php
    Halfords will install it for you.
    Both appear to come with an ariel which runs up the side of the windscreen so you should be able to site it anywhere on the dash, depending upon ariel length ofcourse.
  3. FrankS
    FrankS
    Dec 3, 2005
    422
    28
    +36
