dab aerial
Discussion in 'Music Streamers' started by monkeyboy69, Jan 26, 2003.
  1. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    having just got hold of the arcam DAB, I was a bit miffed when I could hardly get any reception with the aerail supplied out of the box .
    I didn't really consider myself to be in such a bad reception area and dont' really have that much problem with FM reception.
    So can anyone recommend a good DAB aerial at a reasonable price and perhaps give an idea of how to set these up? I'm presuming like a tv aerial the higher the better and so running a length of 50ohm cable up to the loft and then putting some sort of aerial there but any help would be appreciated.
    I hope I haven't put anyonne off because on the stations I do get a good signal the quality is unreal and easily surpasses FM.
  2. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    I've got an Arcam A10DAB tuner at home, the supplied aerial was pretty useless. I bought a Antiference DAB aerial for £25, they also do a non-directional version for £15, mine is directional and needs pointing towards Crystal Palace transmitter.
    I bought it from the Videologic website shop, but there are loads of other places that sell them aswell for the same price.
    I can highly recommend it, I can get 54 radio stations on it (last count). It has it's own direct feed from the roof to the back of the Arcam unit with no joins.
    ED: Just noticed it's the same one as the above link. Just cheaper I think.
    http://www.videologic.com/Products/SalesFrame.asp
    Go to the Accessories page.
