DAB Aerial
TOMMO3108
I have an AS SP110 DAB Tuner, using the supplied aerial. I have an external FM aerial I no longer use; is there any way I can adapt this to use with the DAB tuner?
Chris Muriel
You could try the FM aerial but it is cut for Band II , 88-108 MHz ; it might be adequate if you happen to be in a very strong DAB signal area.
DAB is in Band III around 220 MHz.
An old VHF ITV aerial would work - the old channels 6-13 if my memory serves me correctly.
Chris Muriel, Manchester
TOMMO3108
Cheers; have given it a try and it works fine. Picking ups approx 35 stations including the often temperamental local BBC radio....
