Dab Aerial for AV32R inc Dab obviously
Discussion in 'TAG McLaren Audio Owners' Forum' started by AMCross, Sep 1, 2005.
  1. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    Hi guys have a look at this picture from antiference i believe that the aerial must be fixed as in the picture not like a normal tv aerial :lesson:
    Have i been told a porky or was the guy right don't feel very comfortable with his advice when he told me he would order in a Triax dab aerial and this Antiference 3 elemnet not four as in the picture turned up all for £40 :thumbsdow
  2. ttagster
    ttagster
    Feb 24, 2005
    74
    DAB antennas should be vertically polarised, hence the elements in the picture running vertical.
    The chap appears to have given you the right info. :smashin:
    ttagster
  3. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    TTAGSTER
    cheers mate was just surprised at the quality of the antiference aerial for £40 quid
    But have installed it up the loft and connected it to the AV32R at last :rotfl:
  4. ttagster
    ttagster
    Feb 24, 2005
    74
    I recently purchased a 6 element DAB antenna from Maplins. It cost approx. £25.
    It gives me 8 - 9 bars on the signal strength indicator.
    £40 does seem slightly expensive but then again antiference have a reputation for quality products.
  5. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    Thats my point i thought the quality was crap :thumbsdow
  6. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    Location seems to make a hell of a difference to the quality of DAB reception. I got nothing at all out of the little tail that came with the processor. Steve Jones, who live about a mile from here is using it on his and having no problem at all.
    I originally went for a dipole because I didn't want to be restricted by directionality. I still get the occassional sinking submarine sound, so I guess I should have opted or a Yagi instead, which is what the installer had in mind until I told him otherwise (Ow! there's another hole in my foot!!).
    It looks as if you have it already well under control but PM me if you want the original TAG PDF on the subject.
  7. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    sorry guys i meant to say the quality of the aerial construction etc is poor not the quality of sound :smashin:
    but yes i would like that pdf is poss thanks
  8. edward
    edward
    Apr 2, 2003
    870
    32
    Reading
    +29
    Done!
  9. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    thanks edward :hiya:
  10. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    The antiference DAb aerial is about the only one that does the job properly according to all our tests..... but like Edward says, location can make all the difference.... Oh and £40????? Its £25 in CPC......
