DAB Aerial connection.
Discussion in 'Music Streamers' started by Zog, Jan 13, 2005.
  1. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
    Wasn't sure where to post this..... but here seemed as appropriate as anywhere else.
    Need to use a loft mounted aerial with me new DAB. First I need to remove the telescopic aerial it came with.
    Unfortunately the F Connector is recessed into the body so I can't get a spanner/pliers around it.
    I have found this spanner which I think will remove the aerial. However it wont be much use re-attaching the cable unless I buy an additional one and thread the cable through before attaching the F Connector plug. Leaving it permanently on the cable.
    Anybody got any better ideas ?
  2. AMc
    AMc
    Nov 20, 2000
    5,626
    Near Norwich
    +2,184
    Seems a bit wierd of them to use an F-type connector then not make it accessible -
    Have you contacted the manufacturer to ask their advice?
    You could (possibly) get the spanner and remove the telescopic aerial.
    Clamp the spanner in a vice and use a hacksaw to cut a slot down all the way down one side - so from the top it looks like this
    C.
    Then use it to attach your new downlead and slide the spanner up and off the cable?
    Unless you're planning on doing a lot of this type of thing then I would be tempted to buy one spanner and just leave it on the cable. At least when you decide to move the radio you'll be able to find the tool! :)
  3. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
    Its a Ferguson and there is no trace of any contact numbers, either with the radio or on the net.
    So it looks like the latter is my only choice.
