Da-Lite Screens
Discussion in 'Projectors, Screens & Video Processors' started by Porrm, May 8, 2002.
  1. Porrm
    Porrm
    Now that I've ordered my AE100! Oops I just felt lots of people stop reading! Maybe we should come up with a code name:D
    Anyway now that I've ordered ahem, the PJ, I'm thinking about screens.
    I was considering getting a Da-Lite Model B 69" by 92" matt white.
    Does anyone else use this type of screen with this PJ or should I be going for a grey screen?
    Also does anyone have a problem with these screens curling at the edges?
    Stay Calm folks!
    Porrm
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    I've got a Model B 70 x 70 and it's fine.
    If you do buy one, have CSR put on it, you won't regret it.
    As far as picture quality goes, it's very good for a sub £200 screen.
    To better it I'd expect to pay a lot of money.
    Buy with confidence, unless you have a fair amount of funds ready, a totally dedicated room and want the n'th degree of performance, then you'll need to speak to a proper installer, like Gordon, Uncle Eric and the like that pester us here at the forums.
    ;) :D
  3. Porrm
    Porrm
    Thanks for the reply!
    What is the main benefit of the CSR then?
    I don't really understand what it does!
    I will only be watching things in widescreen does this matter?
    Cheers.
    Porrm:confused:
  4. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    Controlled Screen Return.
    Basically when you retract the screen it rolls up very gently indeed. The speed can be altered easily too. TimH put me onto it as he had a few problems getting his one without CSR back into the case easily.
