D7000 lens advice
Discussion in 'Photography Forums' started by chrism_scotland, Feb 21, 2013.
  1. chrism_scotland
    chrism_scotland
    Nov 5, 2006
    4,102
    Edinburgh
    +291
    Looking for a little lens advise! Only one I have is the 35 1.8G and will probably add the 50 1.8G as well but just wondering what I should be looking at wider?
    Possibly thinking about another wider prime perhaps in the 20-24mm range and then adding an UWA lens for when I need it (8-16, 10-20 or 11-16?)
    UWA I'm happy with and would possibly go for the cheapest Sigma 10-20 as I've had a adele on other bodies but in regards to a prime in the 20-24 range which one is worth buying?
  2. Magnusrn
    Magnusrn
    Feb 13, 2013
    83
    +6
    budget for the 20-24?, and near enough everyone will recommend the 11-16 for the uwa, faster and great optics fwih, although it doesn't have hsm, the one advantage of the sigma, asides from the extra zoom range.
  3. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    Chris, if a second-hand Sigma 8-16mm comes up, just buy it! The Sigma 10-20mm was good, the 8-16mm is excellent.
  4. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    8-16 cant use filters?
  5. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    So?
    That's what rubber bands are for.
  6. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
  7. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    You don't use rubber bands and blu-tack to hold your filters on?
  8. chrism_scotland
    chrism_scotland
    Nov 5, 2006
    4,102
    Edinburgh
    +291
    I have always fancied the 8-16 and it does seem to go relatively cheap used filters are a pain but ice seen some workarounds.
  9. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    No, I find the way they are intended to be used better, that must be for those kind of people that make bits for their flashes out of pringles tubes :D
  10. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    I made a ring-flash from kitchen foil and microwaveable bowl. A few bits of rubber band doesn't scare me. :D
  11. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    :laugh:
    I found a pic of you.....
    [​IMG]
  12. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    That cat looks like, "please God, make it stop"....
  13. twist
    twist
    Nov 19, 2006
    16,315
    +4,992
    :rotfl:
  14. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    42,132
    11
    13
    167
    ::1/128
    +15,561
    I went for the 8-16 at the time, whilst trying out all the others in the shop. Got it from SRS Microsystems. I wanted something that really does go wide.....
    I must admit, I don't think I really am a wide shooter as I haven't used it a lot at all...But a nice lens regardless...
  15. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    :devil:Make him an offer Chris! Do it! Do it NOW!
  16. arthurdentpc
    arthurdentpc
    Jun 6, 2006
    1,069
    +105
    Instead of a prime plus a wide zoom, have you thought about the Nikon 12-24mm f4 AFS DX ? Can be bought 2nd hand for around £500 now and would complement the 35 f1.8 and 50 f1.8 well.
    There really are no DX specific wide primes.
