D70 Continuous shooting mode
Discussion in 'Photography Forums' started by Madcarpy, Aug 16, 2005.
  1. Madcarpy
    Madcarpy
    Apr 23, 2005
    Bath
    Hi all,
    Been a while since I looked in on this site and I am aware that I still have not got round to posting any of my pics :nono: I will soon :)
    I have a question....
    I have not had the best of luck since I bought mine a few months ago. The sensor was seriously contaminated with dust but thankfully Jessops just did a straight swap with a new body.
    The sensor is now fine but I have noticed a marked difference when using continuous shooting mode. With the first body I am certain I was getting very near if not around 3 frames per second.
    The 'new' camera just doesn't seem to be able to acheive that. I reckon I am lucky to get 2 frames per second :(
    I went back to Jessops today and the guy suggested that I should download the firmware update and this should help. Well....... it has not.
    I'm beginnig to think its something I'm doing but no matter what I do, it still struggles to take 2 per second.
    Anyone else come across this 'problem' with continuous mode?
    Any suggestions?
  2. RobertP
    RobertP
    Nov 21, 2002
    529
    19
    Woodford Essex
    Try manual everything including focus to see if some setting is slowing it?
  3. Madcarpy
    Madcarpy
    Apr 23, 2005
    Bath
    Just tried that Robert and virtually the same speed. No change :(
    Just timed again and its taking 2 seconds for 3 frames. :(
  4. RobertP
    RobertP
    Nov 21, 2002
    529
    19
    Woodford Essex
    There are a couple of D70 owners here. They will be able to help you more. Bound to be around before too long.
  5. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    are you using the same flash card in both situations and what make(s) are they?
  6. paulc1
    paulc1
    Oct 19, 2004
    397
    +27
    turn off the noise reduction feature and see the difference in speed. :smashin:
    a bit that I have cut and pasted from ken Rockwells D70 review. below
    Selectable long exposure noise cancellation (NR) mode. Watch it, the camera only runs half as fast even at short shutter speeds when you set this. I wish the camera were smart enough to disengage this mode automatically at fast shutter speeds. You may or may not want to set it for time exposures and definitely want to leave it off (the default) for normal use.
  7. Radiohead
    Radiohead
    Dec 24, 2001
    4,392
    Amazingstoke
    +432
    I can squeeze off 3fps or thereabouts shooting RAW without any trouble on my D70. Have to say I haven't read of this as a known issue with D70's, so maybe you're just being unlucky.
  8. Madcarpy
    Madcarpy
    Apr 23, 2005
    Bath
    Paul, thanks for that :)
    Yep, its much faster with the NR off :clap: :clap:
  9. paulc1
    paulc1
    Oct 19, 2004
    397
    +27
