D500 keypad trouble...
Discussion in 'Mobile Phones Forum' started by Spealtrong, Mar 23, 2005.
  1. Spealtrong
    Spealtrong
    I recently bought a D500, it worked for an hour then the keypad just stopped working. I switched it off then back on again, the only key which works is the power key! any easy ideas how to fix or shall i just send it back?
  2. Spealtrong
    Spealtrong
    nevermind, im sending the phone back to O2.
    Never buy from O2 on contract, they give you nothing but problems.
