D2011 to EVO3B Connections
Discussion in 'AV Receivers & Amplifiers' started by bonoman, May 19, 2003.
  1. bonoman
    bonoman
    Dec 11, 2002
    43
    I'm considering purchasing the Pioneer VSX-D2011 & Acoustic Energy EVO 3B Speaker Package. I'm wondering if I'll be able to connect the speakers to the D2011 using cables such as the QED Silver Anniversary terminated with 4mm banana plugs at both the speaker & reciever ends? I'm asking as I have not yet physically seen the D2011 or EVO 3B speakers & am unsure of the connection types. I've never had any good quality equipment like this (currently own Videlogic Digitheatre DTS sub/sat unit with the basic springclip terminals where the bare speaker wire is connected) & so am unfamiliar with the connectivity.
    Thanks in advance for any feedback or advice..
  2. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    4mm Banana plugs will be fine - though there'll probably be little stoppers in the end of the sockets on the amp end which need levering out with a screwdriver or similar.
  3. jhjerpe
    jhjerpe
    Mar 1, 2003
    700
    2
    28
    North London
    +58
    The little plastic stoppers in the 2011 can be tricky to get out..... but I seeem to be the only one with fumble hands around here....
  4. bonoman
    bonoman
    Dec 11, 2002
    43
    Thanks for the advice & feedback - its much appreciated.
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,343
    Southsea, UK
    +101
    A cork screw worked best for me with the stoppers.
