The D-Line stuff he intends using is surface mounted mate, it doesn't get chased into the wall. http://www.d-line.co.ukHi
Surely does it not depend on how many cables you want in the trunking. I would have thought that as long as the hdmi plug goes through it and as many speakers cables you need to go through with all of them not being tight you should be ok. If its going to be chased into a wall the smaller the diameter the less you have to chase out as well.
hope that helps a bit
cheers Allan![]()
As title suggests....I'm looking at purchasing some lengths of D-Line trunking. It needs to carry speaker cable and an HDMI cable, which diameter is the best to go for?
