Czech PV500 TV - will it work in UK in 2yrs?
Discussion in 'Plasma TVs Forum' started by hippo, May 30, 2005.
  1. hippo
    hippo
    I'm on the verge of buying a Panasonic TH-42PV500E but I'm currently living in Prague, Czech Republic. I'm wondering if it will work when I come back to the UK in a couple of years. I understand the sound encoding is different somehow.
    Interestingly the specs on the Czech website and in the literature seem to offer more tuner compatibility than the UK spec:
    NICAM - B, G, I, L, A2
    PAL B/G/H/I D/K
    (whereas the UK model spec only mentions PAL -I)
    Will the Czech model work in the UK when I come back? Will it matter, or will everything be digital by then? I noticed that the Czech spec doesn't mention DVB but the UK spec does. Is this likely to be important?
    Note that I don't actually need to receive a terrestial signal in Prague right now as I'm completely clueless on the language!
    Advice or opinions greatly appreciated!
    :lease:
