cybrey
The wife has always told me "Once we're detached you can have a home cinema", well I'm paraphrasing but I'm sure thats what she meant. This summer we moved to a detached house for the first time. Many a house was rejected because it simply didn't fit in with the projector or the telly.
I already have most of the equipment that I'll need ( although the list of stuff I'm buying seems to be huge). At the moment we have;
The Telly will be replaced with a plasma shortly. Right thats the equipment out of the way, onto the room.
The room measures about 5m by 3.5m;
This glass window ( partition) you can see will be converted to a cd / dvd storage area.
and from the other side...
The plan is to have the projector ceiling mounted above the seating area. A hifi stand has been purchased ( can be seen in the second picture), this will go half way along the right hand wall. All cables will be sunk into the wall from this point and run around the room. Where the telly currently sits a partition wall will be constructed to hang the plasma from. Above this a pelmet will hide the electric projector screen.
Finally my sons room is partially above the lounge as I'm taking up some of the flooring anyway to lay the projector cables soundproofing will be put down into the rafters.
- Panasonic 36" Telly
- Panasonic AE700 PJ
- Speakers ( Front : B&W 603, Centre : B&W LCR60, Rears : Misson 77DS)
- Yamaha 640RDS amp
- Denon 1910 dvd
- Xbox 360
- Pronto ru950
