cyrus smartpowers amps
Discussion in 'AV Receivers & Amplifiers' started by icequake2000, Apr 19, 2002.
  1. icequake2000
    icequake2000
    Jan 12, 2001
    171
    devon
    +16
    Can anyone tell me if cyrus smartpower amps are any good for AV thanks
  2. juboy
    juboy
    I have a Cyrus Smart Power as part of a bi-amped hi-fi set up and am very, very impressed with it.
    The only slight drawback I would suggest is a touch of bass lightness... but assuming you'll also be running a sub in an AV set up that won't be an issue.
    Personally I think they sound (and look) fantastic. They also give you the advatange of being able to mono-block them at a later date (raising the output to 115wpc) and also adding PSXs to all of them (which when used on a mono-blocked SP will give 125wpc!).
    I also recall Hi Fi Choice and What Hi Fi doing tests with Cyrus kit (including SPs) and it coming very highly rated.
  3. Bonesy
    Bonesy
    Feb 22, 2002
    1,149
    Wiltshire
    +28
    except for the silver ones, which look like they are made from cheap plastic ;)
  4. juboy
    juboy
    I have to agree, you really can only buy black Cyrus kit. I'm not sure what they were thinking with that 'silver' finish.
    It is a bit sad when companies such as Cyrus and Rega feel they *have* to offer crummy silver versions of their kit.
