Cyrus IIIi - PSX modification
Discussion in 'AV Receivers & Amplifiers' started by mal165, Mar 10, 2005.
  1. mal165
    mal165
    have recently upgraded from a cyrus IIIi to an 8X. had IIIi modified by cyrus dealer to allow a PSX-R to be used.. Now want to move IIIi on to a friend and need to know which leads require swapping inside the IIIi to return it to the original setting and allow it to be used as a `stand alone`. Nearest Cyrus dealer is 200 mile round trip away!!
  2. D-man
    D-man
    Nov 8, 2004
    280
    +5
    I don't know if it's the same principle, but my cyrus2 just required a fuse being replaced if used without the psx.
  3. Tee Tee
    Tee Tee
    Apr 3, 2002
    125
    Shropshire
    +3
    Try here:
    http://www.cyrusunofficial.co.uk/
    There's plenty of info available on that site. I did it on my old Cyrus III and IIRC it involved swapping over a couple of cables. Took longer to take the case off!
    Hope this helps.
