Cyrus CLS50c Any Info?
Discussion in 'Home Cinema Speakers' started by grainge, Apr 13, 2003.
  1. grainge
    grainge
    i bought this Cyrus Centre speaker for the net last month and i am just about to set it up when i recieve my Arcam AVR200 to compliment my current Arcam DV88.
    I bought it for £135 and it normaly retails for around £350. So I had to buy it even though it will run with two Mission M73 fronts(I already have) and Mission M5ds rears when I get them. The only review i found said that it was supperb for a £350 centre speaker but i have no more info on this speaker at all and cannot find any reviews on this. Does anyone have any listening experiences with Cyrus; and the above to be specific.
    i would appreciate any info as i am very new to the HT arena.
    Nick
  2. Ravi 123
    Ravi 123
    I brought from creative audio on a trial basis with my B&W's at a mier price of £160. I've only had a week but its had about 60 hours non stop play. Anway this speaker is great espically for £160 i would even contemplate buying this centre for near the RRP price. Ive tried many centres over the last couple of months B&W LCR6S2 and S3, B&W CC6 this speaker is very neutral and dialogue is great. Just need to change my fronts and ill be happy for little while anyway.
    Ravi:D
  3. Boozyuzi
    Boozyuzi
    Aug 10, 2002
    527
    Edinburgh
    +34
  4. grainge
    grainge
    what fronts would you go for as i thought they had to be timbre matched. Would my Mission M73 be ok with the cyrus . And what if I got some MS 903s Bipoles for the rear instead of mission M5ds. Would this make a difference.
