Cyrus CLS-70 speakers
Discussion in 'Home Cinema Speakers' started by benbo, Mar 31, 2005.
  1. benbo
    benbo
    Mar 25, 2005
    26
    Hi guys
    Can anyone help - I'm thinking about a pair of CLS-70s fronts (@ http://www.creative-audio.co.uk/cls70_black.htm for £349 - not bad)
    - do they have to be mounted on their tripod stands, or would any stand do? :confused:
    any help would be appreiciated!
    cheers
    Benbo :D
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    No & No.
    The stand must be solid and rigid enough to support them. The ability to mass load them is also an advantage, as well as spikes.
    Provided the above is satisfied, IMHO, a stand is a stand. :hiya:
  3. benbo
    benbo
    Mar 25, 2005
    26
    thanks :thumbsup: , what dyou recon to Partington dreadnoughts - up to the task? they're doing that for £129 :) . I like the looks but the CLS-70 was an £800 speaker so I guess the stands would have to be fairly substantial.
  4. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Perfect, infact more than up to the task.
  5. benbo
    benbo
    Mar 25, 2005
    26
    Brilliant - I'll go for that then! Thanks for your help!
  6. benbo
    benbo
    Mar 25, 2005
    26
    Received speakers from Creative - they sound every bit as good as I thought they would - very pleased! :thumbsup:
  7. bt521hs
    bt521hs
    Jun 10, 2004
    95
    +3
    would they rate at £800 or £400 speakers? Getting itchy myself. I have a set of now defunct shan's from NI, equivalent to the original proac tablettes and just alittle under the original AE1's.
    Kind of tempted by price range alone, as I am unlikely to have these available to demo near Belfast. Additionally, the aurum cantus imported also appears equally tempting. :hiya:
  8. benbo
    benbo
    Mar 25, 2005
    26
    I would say definatly towards the £800 mark - I prefer them to a pair of Naim intro 2 speakers I heard for example.
  9. benbo
    benbo
    Mar 25, 2005
    26
    they've just dropped the price by £50... :(
  10. stevos
    stevos
    May 16, 2004
    6,123
    +562
    Anyone know if they are bi-wireable?
  11. benbo
    benbo
    Mar 25, 2005
    26
    yes they are bi-wireable :smashin:
