Cyrus 8 + Smart Power???
Discussion in 'Hi-Fi Stereo Systems & Separates' started by thfcwestlower, Sep 30, 2004.
  1. thfcwestlower
    thfcwestlower
    Sep 26, 2004
    186
    +11
    Do any of you guys know if it is possible to combine a Cyrus 8 amp with a Cyrus Smart Power to create a pre/power combo (with the Cyrus 8 integrated amp acting as the pre amp)?
    Cheers.
  2. Pikman
    Pikman
    Yes, the Cyrus 8 can be used as a pre-amp when fitted to a Smartpower.
  3. recruit
    recruit
    I would use the 8 amp and use the smartpower to biamp, so use the 8 to feed the tweeters and the smartpower to feed the bass or vice/versa depending on how you think it sounds in your system.
    Here is a link from cyrus
    www.cyrus.co.uk/upgradeability.htm
    John :)
  4. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    Definitely biamp if you've got the option.
    If this isn't an option just plug the speakers into the smartpower and link the 8 and the power with the pre out connectors with a phono interconnect.
    Bi-amp if you can, it'll probably sound a lot better.
  5. Zod
    Zod
    Sep 20, 2004
    40
    I have a Cyrus 8 and SmartPower and have them bi-amped. The SmartPower feeds the mid-range and treble drivers and the Cyrus 8 feeds the bass. It works very well.
    PS this is my first post here, so hello!
