cycling fan on Domino 30h
Discussion in 'Projectors, Screens & Video Processors' started by m0v1em4n, Sep 6, 2005.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    I have a question for perhaps Alan Roser, or any in the know
    I have a Domino 30 H which is aprox 1 month old with 70 hours on the clock, and now when i first start it up the fan seem to cycle between high and low the domino is ceiling mounted on a proper sim bracket and the room temperature could be classed as normal, when the 30H as been on a while the cycle is not as evident, any ideas
    Steve
    Reposted with proper title
  2. Timmy C
    Timmy C
    Oct 10, 2003
    4,519
    +218
    I didn't even realise the fan had two speeds! Can't say I've ever noticed it on mine and it's mounted the same as yours. I'll pay more attention when I switch it on tonight.
  3. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi Timmy
    I think there is some form of electronic in there that regulate the fan speed according to the temperature, I would say that when the domino is first switched on that the fan would be low getting faster has the heat build up :confused:
    Steve
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    All single chip Sim2 projectors have single speed fans.
    Jeff
  5. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi Jeff,
    Cant understand Why it sound as if the fan speed increases then decreases :confused:
    Was under the impression that the fan was like a PC fan and there was some circuitry that alters it speed to suit the heat.
  6. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    could be fan vibration. Sligtley tighten the fan screws if you can but dont go mad.
  7. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi gandley
    I have now taken it of the sim bracket and placed it on a shelf temporally and it seem ok now, :confused:
    steve
  8. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    that does sound like fan vibration then. I had the same thing. sometimes it would make the noise, mostly on start up and other times it was fine.
    Moved it to the ceiling and never heard the noise until about 2 weeks later then it did it again. Tightened the fan screws and it was fine after that.....as far as i know
  9. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    fan use to make the noise for about a minute after power on, does that sound the same?
  10. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi Dustin,
    Its not vibration, sound like the fan goes into an high speed mode for just a second or two then back to normal and it does this mainly just after start-up for perhaps 10 mins or so then it settles down after that presume when it get hot, turning it the rite way up as helped although it was there tonight at start-up but went after a while,when I had it on the sim bracket the other night it seem to be there all the time Its just very distracting :mad:
    Jeff said that the fans are single speed, but I thought that there might be some form of temperature regulator as there is in some PC power pack fans, but this seem not to be the case.
    The Domino 20 I had before was ok, was hoping that Alan Roser might pop in the forums and give me his opinion.
    Steve
  11. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Alan is away at Cedia then off to Ireland this week so you probably won't hear from him.
    There is definitely no variable speed control for the fan. Sounds like the fan itself could be at fault.
    You can phone Eddie (head of service at Sim2 UK Ltd ) on 01825 750850 if you want another opinion.
    Jeff
  12. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Thanks jeff
    will do that
    steve
  13. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Here is a sound file of the offending noise
    fan noise
  14. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    Nice sound file.
    My PC used to make that noise and it turned out to be knacked fan bearings.
    not fan vibration.
    When it makes the nosie gentley tap near the fan and see if this make the noise go away.
    Regardless though you need the faulty fan replaced.
  15. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    sounds like you need a new fan.
    Jeff
  16. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Thank all of you,
    This 30H is only a month old :eek: will ring SevenOak to see about repair
    Steve
