Cyberlink Powercinema + remote
Discussion in 'Desktop & Laptop Computers Forum' started by zoidy, Apr 27, 2005.
  1. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
    Hi all,
    not sure if anyone else has seen this but I have just bought the Cyberlink Power Cinema 3 software with remote control and it only cost £12.87!! It's on Scan:
    http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=174647
    The remote has an Infra-red usb adapter that works with normal Windows XP (native drivers) and Power Cinema looks exactly like MCE! The remote even works with Media Player.
    The remote control is the same model that you can buy seperately from Cyberlink.
    I am just in touch with One for all to see if they have any codes that will work with my Kameleon 6 in 1.
    Cheers,
    Pete.
  2. JT
    JT
    Jul 18, 2000
    141
    +4
    Been on the web site no picture up. Anyway does the remote have to see the computer, or can it be in a different room via something like a infra-red sensor. If that makes sense.
    £7 for carriage is a bit steep though. :eek:
  3. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
    Yep, the remote has to be in the same room, but you may be able to get some sort of infra-red extender system from somewhere.
    The Scan delivery charge is high, but I think it's still cheap considering the official Media Centre remote is approx £22 plus delivery from other places and that remote is only for Media Centre.
    Here is the remote by the way:
    http://www.gocyberlink.com/multi/cyberstore/product_order.jsp?ProdId=44
