Cyberhome & JPEG viewing
Discussion in 'Blu-ray & DVD Players & Recorders' started by aris, Sep 11, 2003.
  1. aris
    aris
    Aug 26, 2002
    209
    +13
    I'm looking for an inexpensive DVD player that will specifically Display JPEG images on a standard ISO CD-ROM. I've heard that the Cyberhome CH 405/505 will do this - but can't seem to find any suppliers in the UK. Does anyone know of any?
    Alternatively does anyone know of another 'budget' DVD player that will do this - in addition to the usual VCD/SVCD & MP3 support. Something that is currently available in the UK would be ideal.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    The 405 is here
    and the 505 is here ;)
    Cyberhome offer a 2 year swap-out warranty as standard. Hope this helps :)
  3. aris
    aris
    Aug 26, 2002
    209
    +13
    Fantastic - thank you! Cheap too.
    I also found another piece of kit which seems to retail for about 50 pounds - the Ronin P215. Has anyone used one of these?
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
