Cyberhome CH-DVD 400
Discussion in 'Blu-ray & DVD Players & Recorders' started by stubags, May 7, 2003.
  1. stubags
    stubags
    I was wondering through WHSmith in Holborn yesterday, and they had a pile of Cyberhome CH-DVD 400's at £49.95 while stocks last. They're quite small, no display machines, but they have reasonable connections (RGB scart, S-Video, coaxial, LR steroe out) and a remote.
    I bought it on the spur of the moment because I thought my kids could use it. Took it home, wired it up and it's great. Picture's good - might not be as smooth as my other player, but fine. Managed to remote hack it to multi-region too (and my RCE disks worked no problems) by changing the region setting to zero after doing the following:
    Opened the disc tray.
    Press 1,3,6,9,left,left,left,right
    Select the Version option, highlight region 2, press down down until 0 is displayed and o.k. it and exit.
    I found this hack by searching on the internet after which I found one for the 402, and slightly modified it because it didn't work.
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,426
    Yeovil
    +218
    another mediatek chipset dvd player. Most of the cheaper dvd players around the £50 mark are. Great value for money.
  3. Stella'd
    Stella'd
    Jun 2, 2002
    28
    Devon
    Thanks stubags
    A friend has just bought this and was looking for a hack, will pass on the info, Cheers!
  4. Stephen Naylor
    Stephen Naylor
    I got mine in December, it failed yesterday.
    Tech support from cyberhome told me that they had an overheat problem and warned me not to leave it in standby for more than a few days!
    NB Until the point it failed, it was a great little player and they have a 24 hour swap out policy, so I should be up and running again tomorrow.
