cutting wmv
Discussion in 'General TV Discussions Forum' started by dvdmike, Jul 11, 2004.
  1. dvdmike
    dvdmike
    Nov 30, 2003
    854
    96
    +802
    hi all any1 know how to cut a 7gig wmv file in half will wmv encoder do it?
    thanks
  2. encoder
    encoder
    :hiya:
    hi mike,
    you will want to use the app called 'wmv file editor' that installs in the utilities folder with the windows media encoder installation.
  3. dvdmike
    dvdmike
    Nov 30, 2003
    854
    96
    +802
    thanks for that
  4. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    You could also try Total Commander (horrible interface though) which will split any file into files of the size/s of your choosing. When split simply rename the file extension to match the original and it may still play ok. Certyainly does for .ts files.
  5. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    Over the Hill & Far Away
    +139
    or hjsplit as well should be able to do it (freeware)
  6. philjames
    philjames
    Dec 20, 2002
    22
    3
    Swindon, UK.
    Hi, :)
    I think you're going to have trouble splitting it into 2 watchable files, especially as it's a Hi-Def movie. The WMV filetype is notoriously difficult to play around with. If it's just for storage then HJSPLIT, as mentioned above, will do the job. I used this for a film (Minority Report I think) & it it re-joined without a problem.
