Quantcast
Custome made glass shelves required
windfall
Hi All
I'm looking for a supplier to make some glass shelves so that I can place AV gear on them.
I need 5 in total and they have to be made to measure and take the weight of an amp (25kg)
Does anyone know of anywhere I can get these made?
Tone
buns
I know of somewhere but its a local place..... you should be able to get something like this from a half decent glass supplier which should be pretty common
ad
windfall
Thanks for your reply
I looked in the thompson local all seem to lend themselves to windows (non pc type!) rather then glass, I will call a few anyway. I just wondered if any one could recommend any and what sort of cost was involved.
Cheers for now
Tone
Klippie
tonetrainer,
I made a five shelf three pole hifi rack a while back and found a glazier quite local to me ( Edinburgh area ) to make up the glass sheets. All he wanted was a template of the shape and size of glass the thickness and colour of tint. I ended up getting 6mm bronze tinted thoughened glass total cost was aroung £350 not cheap but stunning quality.
If you would like to see a picture of the rack I made PM me your e-mail address and I will send you a photo.
Klippie.
MartinImber
Midlands - call this place - if they can't do it they will recommend someone who can
Brownhills Glass
01922 749910
