This should probably be posted in the Speakers forum, but for some reason the site wouldn't let me post, kept asking me to log in.
But hopefully someone here can help, as it relates to an AV cabinet I'm designing to have built. If you look at the attached picture (and ignore the speakers, which will be used for music separately only), you'll see a circular section on top of which the TV will sit (and revolve). I was originally thinking of a soundbar, because the TV speakers will be inadequate, and I don't need full surround sound - but ideally the curved section would be perforated aluminium with speakers (curved as well?) sitting invisibly within and projecting out through the tiny holes.
I guess simply putting ready-made speakers inside behind a second grille would not be great for the sound quality - is there any way to have speakers custom built to clip into the also custom built curved grille section? Basically, I want the TV speakers concealed and perfectly integrated within that section...
Thanks!
Thanks!
