Custom size open frame rack
Discussion in 'Home Cinema Building DIY' started by clarkashford, Feb 18, 2014.
  1. clarkashford
    clarkashford
    Feb 18, 2014
    12
    Hi guys
    Looking for a place in the uk where i can purchase a custom sized open framed rack. Its going to sit in my av cupboard which has a max height of 150cm and a depth of 40cm
    I've looked at getting some timber and creating one myself but i need the flexibility to swap and change components plus i will have a lot going in there also which is why i need a steel frame upto 500lbs worth of equipment.
    Anyone know of a supplier where i can possibly get one custom made.
    I have seen one that is slightly taller than i would need but perhaps i could have it cut down maybe?
    Clark
  2. Geps
    Geps
    May 7, 2011
    1,137
    63
    +181
    Why not just try your local steel fabricators - they'll be able to knock something together for you..
  3. clarkashford
    clarkashford
    Feb 18, 2014
    12
    I hadn't thought of that thanks geps. I have a cheap small unit coming so I guess I can give them an idea from the website what I want them to do. I actually used to work for a power coating company so I can take it there when done.
    Nice shout,
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    .... or you could get stack smaller ones
  5. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
