Custom Made Scart-SVHS cable problem - Help
Discussion in 'Cables & Switches' started by Gliese 581c, Sep 10, 2004.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,831
    On AVForums
    +522
    guys, I have a head scratcher here and i hope someone can tell me whats wrong. I have made up a
    custom scart to s-video cable. The problem I have is that If I connect the scart to my TV and the
    s-video to my DVD player it displays fine in all its full colour glory. The problem I have is
    that if I plug up the svideo to the TV and the scart to the DVD it doesnt show properly at all,
    its all wavey lines and the picture doesnt show at all. - I actually need it to work that way and
    I'm stuck to find an answer why it works the way of TV (scart) and DVD (svid) but it wont work if
    the cables are plugged up TV (svid) and DVD (scart)
    Can someone help me please ?
  2. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,831
    On AVForums
    +522
    no-one knows why this is happening, or cant help ?
  3. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Its because the pins for the output and input of S-vid on a scart are different. You cant make an omni directional cable unless you have two S-vid cables connected to the same scart cable :thumbsup:
  4. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,831
    On AVForums
    +522
    ahhh, so i have the scart wired for input and i should have it wired using the output method ?
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    swap pin 19 and pin 20 in the SCART connector
    and it will work SCART/dvd to s-video/tv
  6. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,831
    On AVForums
    +522
    thanks pjclark, I will try that shortly.
