Custom length USB extension cables
PhillyG76
Does anyone know any companies that can make good quality USB 3.0 male to female extension leads? I have a Pioneer headunit in my car and I think it’s just over a metre in length (The supplied lead)and I think a metre will be too short. Also it looks a bit fragile, and If I had to change it, it’d be a ball ache. So I want to get the best quality one I can, and this maybe overkill but try USB 3.0 because using WebLink sometimes seems bit laggy so just want to make sure everything is as good as it can be. That said the port from the headunit may only be USB 2.0, but for the small difference in price I’d rather get the best I can. The Ugreen range looks good but not sure if one metre may be too short to run though glovebox and two metres too long. I’m really quite anal with cables. Like Ethernet ones, I look at HIFI branded ones to see if there are any that have unique features for not much more than a normal high quality lead.
