Custom Furniture build
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Mora, Dec 19, 2004.
  1. Mora
    Mora
    Jul 16, 2003
    80
    11
    Does anyone know anyone in the South of England that can build custom furniture. aka: similar to the sort of thing that Carpenters would do for some of the big AV people.
    I have a whole wall that needs designing and turning into an AV heaven. :)
    Steve
  2. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    Any good carpenters/cabinet maker should be able to produce this.
    Here are few you can try:
    Centreline Shopfitting ltd,(Essex) 01268 820 033, as used my Musical Images for custom installs. for a 14ft wide and 8ft tall cabinet for all my gear they wanted 6k.
    Kilakita Joinery Ltd, (London) 020 8376 5556. Very good company, very very good quality work. For a 14ft wide AV cabinet in solid American white oak was 3k
  3. Mora
    Mora
    Jul 16, 2003
    80
    11
    Thanks a lot Pemberto, thats exactly what i was after. (thanks for the double post as well) seems i'm not the only one with that sort of thing in mind.
    I have a whole room to convert into a 'cinema' and at barely scratching the 'Research' Stage at the moment.
    Steve
  4. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    Steve,
    More than happy to help. I have been down this long road myself. If I can be of any more help feel free to PM.
    With regards to Kilakita Joinery Ltd cant recommend them enough.
    Paul
  5. AMc
    AMc
    Nov 20, 2000
    5,626
    Near Norwich
    +2,183
    If cash is a bit tighter then www.jali.co.uk will do fixed pattern MDF furniture to your dimensions. There is a designer application and the quality of the final product is great if you can spend the time on the paint finish.
