jibby said:If your looking to sleeve them yourself there are really good video guides over on OC:
Video Sleeving Guide Series
Frequently Asked Sleeving Questions
For my supplies i buy from watercoolinguk or specialtech
Mod/Smart Molex Plugs, Mesh, Acrylic Panels, Thumb Screws, Heatshrink and Braid >> Watercooling UK
Braiding & Heatshrink |Specialtech UK Water Cooling Shop
or you could avoid the hassle and buy sleeved cables like the corsair ones, but they only work with corsair PSU's the only other ones i would recommend are the bitfenix pre sleeved extension cables but you end up with a lot of cable to hide
Looks good and fairly easy to do. Is it as easy as it looks?
