Custom Built Scart Cable
Discussion in 'Cables & Switches' started by shaneh, May 2, 2007.
  1. shaneh
    shaneh
    Sep 8, 2006
    42
    Hi all,
    I'm wondering if people can help with the following question.
    I currently have the output of set topbox connected to my Sony 40W2000 via a Scart connection. I'm using the standard cable that came with it. The set topbox is unusual in that it is IP based, ie signal is over Ethernet
    http://www.aminocom.com/products/ipstb/aminet110.html
    1) I was wondering if I got a good quality built cable with gold connectors would the quality improve much??? The quality is not bad but there's always room for improvement! Since signal is IP based, I would think the only possible source for signal degradation is the Scart connection itself.
    2) The output of the set topbox is unusual, 10 pin mini-Din, so I can't find any standard cables and therefore would need to get it custom made. This is the pinout I found on web but would need to verify this
    http://www.mycableshop.com/learning...quently+Asked+Questions+&+Guides&question=457
    Is it possible to get such a cable made?
    3) Any recommendations on who can provide such a service as custom built Scart cables with high quality?
    Shane
  2. shaneh
    shaneh
    Sep 8, 2006
    42
    bump
