Custom Built AV Stand
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by c_fletcher, May 30, 2005.
  1. c_fletcher
    c_fletcher
    Thought I`d share this with the group since I received a little bit of interest when I posted it in another thread here.
    The cabinet is solid oak and made to measure by Yorkshire Pine of Sowerby Bridge West Yorks.
    1550 wide x 490 deep x 600 high
    Drawers are 400 wide external and internal 360 wide x 400 deep
    Cupboards are internal 460 wide x 400 deep x 510 high
    Doors are 530 wide and when open are recessed into cabinet
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Very nice indeed, I particularly like the recessed doors when they're open. :smashin:
  3. Oddbodd
    Oddbodd
    Apr 7, 2002
    1,074
    Sunny Tyneside :)
    +81
    Hi c fletcher, I forgot to ask you, is the cabinet open backed, do you have any pictures of the back?
    Cheers,
    Oddbodd.
  4. c_fletcher
    c_fletcher
    Closed back, screwed on at ~6" centres and down the centre uprights. Holes cut in top and bottom of each cupboard back panel to allow cables to pass through, large enough to accomodate scarts and 13 amp plugs. Too heavy now to pull away from the wall to get any pics.....sorry
  5. Oddbodd
    Oddbodd
    Apr 7, 2002
    1,074
    Sunny Tyneside :)
    +81
    No problem, thank you for the reply.
    Cheers,
    Oddbodd.
  6. AMc
    AMc
    Nov 20, 2000
    5,828
    Near Norwich
    +2,343
    Can I be the first to ask the rude question - how much did it cost?
  7. c_fletcher
    c_fletcher
    £499 delivered, I thought that was pretty good and its miles cheaper than the likes of Arca and Blok, plus its solid oak not veneered MDF and has the retracting hinges for the doors which are £50 ish
  8. Oddbodd
    Oddbodd
    Apr 7, 2002
    1,074
    Sunny Tyneside :)
    +81
    That my friend is an absolute bargain :smashin:, but don't tell the company who made it, not until I get one anyway :devil:
    Cheers,
    Oddbodd.
  9. AMc
    AMc
    Nov 20, 2000
    5,828
    Near Norwich
    +2,343
    I agree that's a flippin' bargain - was it made to order or do they have a design?
  10. c_fletcher
    c_fletcher
    Made to my design and measurements but they probably still have the drawings I provided even though they were pretty basic
  11. roligan
    roligan
    Oct 8, 2004
    37
    Just looked at the ARCA Nuevo which is GBP 725 with the cloth doors. This is much better.
    I onlu need my to be 1000 wide and in cherry. Would that make it cheaper do you think?
  12. c_fletcher
    c_fletcher
    Not sure as cherry may be more expensive, why not call them and see
  13. Ripstop
    Ripstop
    Aug 17, 2005
    41
    Been looking at something like this for a while...looks like you did all the hard work finding a very good buy. I will definately be giving them a ring.....
  14. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Reviving a very old thread here, but I've just placed an order with YP myself for a very similar setup. Mine's basically a slightly deeper and taller version of the (now discontinued) Acra Nuevo which Ian at YP has agreed to recreate for me. It's similar to this design, in oak, same style foldaway doors, but with a centre speaker space in the middle rather than drawers.
    I'll update with photographs when mine arrives (in 6 weeks, apparently).
  15. Carlos13
    Carlos13
    Dec 11, 2004
    146
    16
    Peterborough
    Do the doors recess back into the cabinet the whole way or in the picture above are they pushed back as far as they will go?
  16. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    That's as far back as they go I believe. Mostly because the width of the door is a fair bit more than the depth of the cabinet.
  17. thudspud
    thudspud
    Mar 28, 2002
    2,279
    Sheffield
    +89
    Pictures would be great when you get it.
    I am really struggling to find something that fits my specific dimensions, only one I have found is the new blok 3000 but at nearly £800 its a bit much, one of these for £499 could be a winner, has the price changed much for yours since the OPs purchase?
    Chris
  18. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Well, the price has gone up, but I won't say what I'm paying precisely. Ian at YP does work it out based on the design you submit and the material used. All I will say is that they do work out considerably cheaper than the Blok units, they're solid oak, and they're the exact dimensions you need. :smashin:
  19. BarryK
    BarryK
    Nov 18, 2001
    93
    Looks a lovely unit. I do like the door sliding into the unit idea. Does anyone know where these type of hinges are available from as I am considering building my own cabinet here and they would be a great idea to accomodate in it.
    Barry
  20. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Just a quick update, but apparently I was wrong with my understanding of 6 weeks, and it's going to be nearer to 8 weeks. They must be busy :)
    I'm on me 'olidays in 2 weeks time tho, so might be another month before I get photos on here for anyone who might be waiting for them.
  21. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Just another update to say that it was delivered last friday. It looks great too. :thumbsup:
    It's slightly larger than I was imagining, but it's exact to the dimensions I gave them. Quality is excellent and all as I expected.
    I'll put up some photos, probably tomorrow evening (when I'll also be selling my old Sound Organisation black glass stand, for anyone who is interested! ;))
  22. Oddbodd
    Oddbodd
    Apr 7, 2002
    1,074
    Sunny Tyneside :)
    +81
    Looking forward to the pictures.
  23. t72bogie
    t72bogie
    Jul 17, 2007
    3,102
    UK
    +533
    thats excellent - last year I needed a new cabinet and was after one similar...luckily I didnt neet it wide enough for my TV, but basically its nearly the same design as yours, but without the centre drawers. Managed to pick it up in solid Oak for £270 and Im really pleased with it :smashin:
    I dont understand how theres a market for these fancy glass shelve things with mdf drawers at for like £1K+ when you can have such a nice piece of solid wood furniture for half that or less:smashin:
  24. thudspud
    thudspud
    Mar 28, 2002
    2,279
    Sheffield
    +89
    Really looking forward to seeing the pictures as I am now ready to order one of these once I have finalised the dimensions.
    Chris
  25. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Sorry the photos have not been forthcoming! Busy week this week in the evenings. I'll endeavour to get them up tomorrow night.
  26. thudspud
    thudspud
    Mar 28, 2002
    2,279
    Sheffield
    +89
    Any progress on the pictures? Looking forward to seeing them :)
  27. solomyr
    solomyr
    Dec 20, 2005
    Aberdeen
    +9
    Would love to see some pics as this sound like exactly what i am after.
    What dimensions did you get?
    thx
  28. UZUBAIRU
    UZUBAIRU
    Jul 6, 2001
    557
    Manchester
    +23
    Any luck with the photos yet?
  29. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Well, this reply has been a long time coming eh? :D
    Finally got round to takin photos of it in place, so here are the "day it arrived" and the "finally installed" photos! :thumbsup:
    The first shot shows it in situ in my lounge. No comments about the crap on the coffee table thanks :)
    2nd shows it with the doors open and you should be able to see the IR receiver and centre speaker cover - they supplied the frame which fitted like a glove and I wrapped it in tights!
    3rd shows the end of the wood that makes the solid top - very chunky and well made.
    Last shot shows the open back so the cable can easily route and the heat can vent with the doors closed.
    All in all, I'm well happy with it.
  30. Audio Bully
    Audio Bully
    Mar 12, 2006
    73
    +5
    That does look good :thumbsup:.
    I take it that your centre speaker is standing up in the middle.
    Think im gona go down this road aswell as i cant find any tv cabinet that fits my needs.I have a small KEF egg for a centre speaker which makes it hard to find a stand or cabinet to fit in
