Current Toshiba's with Component in (32ZP18)
Discussion in 'General TV Discussions Forum' started by Blighty_Boy, Oct 25, 2003.
  1. Blighty_Boy
    Blighty_Boy
    Im hoping to get a Tosh 32ZP18 which has component in. What I would like to know is if it supports progressive scan , if so at what resolutions.
  2. fatbob
    fatbob
    May 22, 2003
    267
    19
    The Toshiba 32ZP18 doesn't support progressive scan, but it's an old model now, and it has been superceded by two models that do support progressive scan.
    Both the 32ZP38 (PF2) and the 32ZD26 (Strata) accept progressive signals. The ZP38 accepts both PAL and NTSC progressive, while the ZD26 (and the ZT29, which is basically a ZD26 with a digital tuner) will only accept NTSC progressive.
    The resolutions supported are 480 progressive lines for NTSC, and 575 progressive lines for PAL.
    Hope this helps,
    Bob.
  3. Blighty_Boy
    Blighty_Boy
    oh well thanks anyway :) whats the benefit of the component in on my 32zp18 ???
