Current DLPs - are any wall mountable?
Discussion in 'General TV Discussions Forum' started by paul.graham, May 19, 2005.
  1. paul.graham
    paul.graham
    May 19, 2005
    Hi All!
    My post first here, so I'm really sorry if it's a stoopid one.
    I did a quick search and couldn't find any posts on it, but could anyone tell me whether any of the current crop of DLPs can be wall mounted?
    All the best,
    Paul
  2. Gregory
    Gregory
    Mar 27, 2005
    312
    Midlands
    +9
    Only if you have a VERY strong wall to take the bracket to stand them on. There are none that have any fittings on the back that I have seen. If you are determined and do have a very strong wall then I can't think why you couldn't mount them that way, but I'm not quite sure why you'd want to.
    Greg
  3. Razor
    Razor
    Dec 15, 2004
    37,566
    2
    +12,432
    Yes the Thompson DLP thin TV which is a infocus based machine can be wall mounted and is only around 8 inches deep. This set does suffer from poor viewing angles and only direct viewing solves this.
    :D
    http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=5512
