Cure for pixellation / "Noise" on Nebula DigiTV card
Discussion in 'Desktop & Laptop Computers Forum' started by gab2001uk, Jun 13, 2003.
  1. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    This post is not a question, but information for users of the Nebula DigiTV card.
    I recently moved my card to a HTPC in the process of construction, and was disappointed in the quality of the picture, which had been very good previously. Some channels were OK, others un-watchable with pixellation, bands of coplour and audio artefacts.
    I emailed Nebula at midnight with a description of the problem
    10 mins later (Do these guys sleep at night?) I was told the problem is due to the PSU interfering with the analogue components, and a modified card will be sent.
    2 days later a new card with additional electrolytic capacitors and surface mounted resistors arrived, and the picture is perfect on all channels! The original card is on its way back to them.
    The points to note are:
    1) PSUs designed to be audibly quiet eg from QuietPC.com are not necessarily electrically quiet!
    2) Nebula's customer support is second to none.
    3) Other users with a less than perfect picture may be having the same problem
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    I recently purchased this excellent card, and apart from a few bedding in problems, has been quite awesome in operation ever since. Even got student discount on it, probably the best £100 i've ever spent!
    Just checked my card even though i haven't noticed any of the problems you describe, and can confirm that my card also has these caps on the back of the card, guess it's a problem they're already aware of and are changing on newer cards.
    I agree that the support is excellent, i can't wait for them to release all the windows messages i need to control DigiTV from girder.
  3. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Nebula have just emailed to say all future cards will be sent out with this modification. They say about 10% of users are affected currently by noise.
    looks as if they were already doing it if yours has the mod already.
  4. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    I have exactly the same problem as you describe and have also received the new card with extra bits on, but this has not cured it for me. Nebula are scratching their heads trying to work out a solution - any ideas anyone?
  5. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    An electrically noisy PSU? Most interference problems i've read about in HTPC circles have been improved if not removed altogether with the installation of a newer/better PSU.
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    To be honest I replaced a QuietPC PSU for an enermax in the interests of lestening RF interference and I have to say it made no difference whatsover. I actually wish I'd kept the QuietPC one as it was quieter than the enermax.
