Cube to Projector via VGA - US or UK Cube?
Discussion in 'General Video Gaming Chat' started by crawf1982, May 29, 2003.
  1. crawf1982
    crawf1982
    Jun 21, 2002
    170
    East Midlands, UK
    +7
    When I get my gamecube I will be connecting it directly to a projector via a VGA cable.
    Given that I am using this connection, will the progressive scan feature of the US games played on a US Cube produce better video quality than UK games played on a UK Cube?
    Thanks in advance,
    Dave
  2. Luc
    Luc
    Aug 7, 2000
    417
    In a word, yes.
  3. jian
    jian
    Aug 31, 2001
    2,506
    68
    +77
    The UK Gamecube outputs in progressive scan as well provided that the software you use supports it.
  4. crawf1982
    crawf1982
    Jun 21, 2002
    170
    East Midlands, UK
    +7
    jian,
    By that do you mean if I were to play a US game in a UK Gamecube I would get the option to play in progressive scan mode?
    Dave
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,713
    Norwich
    +613
    you will only be able to play us games on your monitor with a vga cable using us software, so why even consider a pal machine.
    Goblin games do US platinum machines for £99 and there are always us/jap machines for around £75 on the ntsc-uk forums used.
    stick with ntsc and get groundy to make you a cable if you dont want to do it yourself and your laughing mate :)
