Cube - Freeloader / Action replay
Discussion in 'General Video Gaming Chat' started by Jamsie, Feb 18, 2003.
  1. Jamsie
    Jamsie
    I've read on various sites that there are few different Versions of freeloader being sold, ie. v1.03 or v1.06, you get the idea?
    My questions are,
    A) Does anyone know what the differences are? (i'm guessing support for more games?).
    and
    B) Which version of freeloader is bundled with Action Replay.
    Thanks in advance.
    Jamsie:smashin:
  2. MattDX
    MattDX
    The later versions support more games (earlier builds had a nightmare playing Res Evil Zero).
    As for AR - it should come with either 1.6b or maybe an even newer version (as it is being released a few weeks after AR)
  3. Jamsie
    Jamsie
    Thanks for the advice Matt, think i'll head over to play and see if thier still selling them at £17.99.
    james.
  4. kev_melon
    kev_melon
    Sep 26, 2002
    55
    9
    I'd rather not say...
    Freeloader is currently on version 1.06, which I've been told has better compatibility with import games, and I'm pretty sure that v1.06 is built into the AR.
    Action Replay for Gamecube. IT WORKS!!!!:D :clap:
  5. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    my upgrade from codejunkies was 1.06b
