Cube Component Lead ( Worth Getting )
Discussion in 'General Video Gaming Chat' started by BIONIC MAN, Oct 29, 2003.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    953
    Nasa
    +38
    I have a Pal GameCube ,
    And I was thinking of getting a Component Lead for it ?
    Is it worth getting one , would the picture be better than RGB ?
    So were is the best place to get one from & best price :confused:
    I was out in the states a few weeks back and looked everywhere
    for one but had no luck , just the S-video leads
    So best place to get one from & is it worth getting one ???
    :smashin:
  2. Erpland
    Erpland
    No the picture is not better than RGB (unless you're running progressive scan capable games)
    You only want one if Component sockets are prominent on your display device (and if they are then it is unlikely it also has Scart RGB) or you want to run imported games in progressive scan mode.
    best place to buy is probably lik-sang.com
