CT100 Extension
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Waser, Jun 4, 2004.
  1. Waser
    Waser
    Mar 1, 2004
    984
    Purley, Surrey
    +57
    I need some help extending my CT100 Sky dish cable by about 3 - 5 meters. I am looking to move my TV to the other side of the room. Is this possible by using an extension of some sort? Or do you have to replace the cable in its entirety?
    If it is possible any ideas where I can get one?
  2. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    A Maplin QQ79L will do this - it's 5m long
  3. Waser
    Waser
    Mar 1, 2004
    984
    Purley, Surrey
    +57
    Great! Thanks a lot pentode! I'll check out a Maplins this weekend.
  4. Fernsehman
    Fernsehman
  5. Waser
    Waser
    Mar 1, 2004
    984
    Purley, Surrey
    +57
    Thanks Fernsehman Maplin's quite close to me though so I will grab the one from there.
  6. Fernsehman
    Fernsehman
    I use Maplin quite a lot but it's not so convenient if you live 100 miles from the nearest! Problem I have is I use about a gallon of petrol to get there and then I buy half the blooming shop. It's just sooo tempting to think "while I'm here I'll just buy a spare firewire cable and a USB2 cable and I rather like the look of those gold-plated connectors and I could do with one of those.."
    So in my case, mail-order is definitely cheaper! :rolleyes:
