Crystalio - continued
Discussion in 'Projectors, Screens & Video Processors' started by cj, Jul 14, 2004.
  1. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    After owning one for nearly 3 months, I've had several people asking for any further thoughts on my Crystalio - I don't really have much to say as basically I've been 100% satisfied :) I've had it running both my projector and plasma, and the picture is stunning on both. After I set it up, I basically left it alone (apart from a few firmware updates).
    One thing I have to mention (apart from the picture) is the user interface and setup - at the simplest level you choose your input, select an output, and choose your display model name from a predefined (and customizable) list.
    That's it - you plasma or projector is now running at native resolution (if that's what you want). There are stacks of options to tweak (e.g. Noise Reduction, Black Enhancer, custom aspect ratios etc. etc.), but getting a fantastic looking picture is a simple exercise.
    One of the the biggest compliments I can pay it is that Mrs. cj is confident using it - I'm yet to get a "I can't get a DVD/Sky picture" phone call.
    Have I mentioned how nice it looks, and you get 2 remote controls (one dedicated, and one fully programmable touchscreen)?
    The only minor niggle I have is when the Deinterlacing mode is set to Auto and I'm watching Sky Sports, it sometimes incorrectly switches to Film mode, especially during slo-mo replays. Easily avoided by manually selecting "Video" rather than "Auto", but I'm picking holes :)
    I'll post more when I think of any.
    Cheers,
    Colin
  2. Alex Simon
    Alex Simon
    Nice one Colin :)
    Have you had chance to play with the new features on fw 3.0.0?
    Black enhancer, etc.
    Re: film mode/auto mode. It's common to all the faroudja based scalers/products we've seen so far. Especially with SKY. That tell-tale blue light is proving usefull.
    We've moved from a well-developed HTPC in my own home setup to Crystalio and I can't say I'm tempted to go back. Only layer changes have proved annoying (I'm just using the panasonic RP82).
    The pronto ccf file's now available too so I'm back to only one remote in the house :)
    Keep the feedback coming!
  3. zAndy1
    zAndy1
    Nov 26, 2002
    22,000
    2
    5
    163
    +8,432
    Blimey, if only my Lumagen was that easy! To just chose a display model name would be a godsend if it set everything to their optimum values!
    Andy
  4. simonm
    simonm
    Mar 21, 2004
    3
    Dear CJ,
    I was wondering about the fan of the Crystalio, does it blow all the time and isn't it too loud?
    Tx
  5. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Hi Simon,
    as far as I can tell the fan is on all the time, but I can't hear it at all in my setup - very small, and silent.
    Colin
  6. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Anyone tried a Crystalio (or a Lumagen with DVI) with a Sony HS10?
    Is a projector upgrade more appropriate first?
    Rob
  7. zAndy1
    zAndy1
    Nov 26, 2002
    22,000
    2
    5
    163
    +8,432
    By the way, what plasma and projector are you using? Are they different resolutions and what connections are you using? Presumably DVI to one and RGBHV to the other?
    Cheers,
    Andy
  8. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Hi Andy, if that question is for me then my projector is a Runco CL-710 via 10m DVI, and my plasma a Toshiba WP16 (Panny 4 clone) via component.
    Hi Rob,
    I personally would make sure my projector was what I wanted before I bought a scaler, although I know nothing about the HS10. The Lumagens with DVI are still in Beta.
    Cheers,
    Colin
  9. Burton
    Burton
    Mar 31, 2004
    37
    CJ
    What DVD player are you using and is it SDI modified?
  10. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    My player is a Tag McLaren DVD32FLR connected via component. It does also have a progressive DVI output, but I now leave those duties to the Crystalio.
  11. AMCross
    AMCross
    Dec 3, 2003
    6,018
    Livingston,Scotland
    +208
    "It does also have a progressive DVI output, but I now leave those duties to the Crystalio."
    So does that mean colin that you may sell me your dvi output board for my DVD32FLR as i stupidly missed out on your AV32R 7.1 EX 192 BP :laugh:
