crystal Xbox soft mod
Discussion in 'Xbox Forums' started by chillo, Oct 14, 2004.
  1. chillo
    chillo
    Sep 15, 2004
    765
    Northern Monkey!
    +30
    I know this has been answered before, just haven't been sure if i'm ok to do this with a crystal xbox (not the lastest crystal xbox)
    I think i have everything i need:
    Crystal Xbox
    Xploder game saver
    007 agent under fire
    cross over lan cable+ laptop (is this really needed?)
    MS hi-def pack and hi def plasma
    where can i get the game save and the right software? is it evox?
    Not been able to find it!
    Is it ok to do a crystal xbox?
  2. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    Yes, I did softmod with 007 AUF on my Crystal Xbox and it worked fine.
    PM me your email address for the savegame with video switcher.
  3. chillo
    chillo
    Sep 15, 2004
    765
    Northern Monkey!
    +30
    pm'd ya Lee!
    is there anything i need to be wary of when doing this?
    Will it still be ok on live?
  4. chillo
    chillo
    Sep 15, 2004
    765
    Northern Monkey!
    +30
    i've just checked my ms cable and its the uk advanced scart with optical out.
    Do i need the official hi def US cable for this to work???
  5. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
  6. chillo
    chillo
    Sep 15, 2004
    765
    Northern Monkey!
    +30
    ok, cheers Lee! i will get there in the end!
    just ordered the official MS hi def lead from mx2.
    one more thing how how do you get the zip file onto the xploder memory card? It doesn't recognise zip files only gsx??
    just found out that you can replace the xploder software with action replay software?
