Crucial 4GB RAM down to £65.79
Discussion in 'Apple Forum' started by opo101, Jan 16, 2008.
  1. opo101
    opo101
    Jul 17, 2004
    227
    +18
  2. munkee143
    munkee143
    Apr 17, 2006
    36
    Edinburgh
    +7
    Just ordered! thanks for the heads up - I always trust Crucial
  3. opo101
    opo101
    Jul 17, 2004
    227
    +18
    No worries.
    I'm tempted to Get 4GB for my iMac, and put the Kingston 4GB currently in my iMac in my MacBook!
    Currently have 2GB in my MacBook.
    Am i being too greedy?
  4. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Thanks for that. Much prefer Crucial to Kingston RAM. Never had any probs with their memory were as the Kingston stuff I've had more than a few issues with when building PC's for friends.
  5. morb666
    morb666
    Oct 21, 2004
    312
    King's Lynn
    +8
    4GB Ordered here :thumbsup:
  6. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Thanks for that. I just ordered the 4gb kit for when my MacBook Pro arrives!
  7. Monopot
    Monopot
    Dec 11, 2006
    2,514
    Auckland, New Zealand
    +190
    I put mine in and freaking slot broke!! Must have been a crack in one of the hinges so its going for repair soon :(
  8. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Not bad. Got my 4GB in today. Fitted it 2 mins and now I can throw 2GB of memory at my VM machine running XP :smashin:
    Now, to get the Mac Mini opened to put my old 2GB in there :D
  9. Ickle Yoda1
    Ickle Yoda1
    Jun 25, 2005
    1,059
    48
    Bathgate, West Lothian
    +88
    Trying hard to resist this, is there anyway of telling if I would notice a big difference with this on my mac? I got my macbook a year ago and its running ok on 1GB.
  10. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Well, going from 2 to 4GB I can really see a speed difference in everything loading up. Also, as I said above, I can now throw 2GB at my virtual Windows machines so these run even better than before and they don't cripple OS X when they are running.
    If you have the dosh then you really should get them while you can.
  11. kraized
    kraized
    Dec 6, 2005
    375
    +17
    Anyone know if the 1G MacBook Pro can take 2GB modules? I know at the time Apple says it can only take 1GB modules but I am wondering if this is a hardware limitation. Can the Core Duo chipset support 2GB modules?
    [EDIT] Don't worry. Apparently its a hardware limitation. :(
  12. Ickle Yoda1
    Ickle Yoda1
    Jun 25, 2005
    1,059
    48
    +88
    how can I find out if my macbook will accept two of the 2GB sticks? I bought my white macbook last year. When I go to about this mac, it says it is 2.16GHz intel core 2 Duo and the memory is 1GB 667MHZ DDR2 SDRAM.
  13. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Ickle Yoda1
    The crucial website lists your Macbook with the following:
    Maximum Memory: 2048MB
    USB Support: 2.x Compliant
    Standard Memory: 1024MB removable
    Slots: 2 (2 banks of 1)
    See here.
  14. Ickle Yoda1
    Ickle Yoda1
    Jun 25, 2005
    1,059
    48
    +88
    Thanks tykent, can you (or someone else? ) please tell me if changing the RAM invalidates my warranty with Apple?
  15. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Upgrading your RAM is easy to do and does not invalidate your warranty. I have a Macbook pro I have upgraded and it was just a couple of screws to undo under the battery and slot the new modules in.
  16. stuart07970
    stuart07970
    Sep 28, 2004
    2,616
    Slough
    +356
    Just ordered mine!!!:thumbsup:
    does anyone know what spec the screwdriver required is???
    I haven't even taken the battery off the back yet!
    I'm assuming its a philips/cross-head???
  17. Ickle Yoda1
    Ickle Yoda1
    Jun 25, 2005
    1,059
    48
    +88
    Well I have just ordered 2GB, its the most my macbook can take but I should notice an increase going from my 1GB I am currently on.
    Can someone tell me though, does the price of RAM sometimes increase? A few people on other forums have spoke about this deal and said to go for it before the price goes up. If so, why does the price increase and decrease?
    STUART 07970 - If you go on the apple site and look under support there is instructions on how to change your RAM and it tells you what size and type of screwdriver you need :) Sorry I can't check for you myself having to nip out the house now!
  18. baldrick
    baldrick
    Dec 28, 2002
    3,370
    Providence, Rhode Island
    +246
    Annoyingly for anyone who ordered yesterday, they've just dropped the price again to £52.63!!!!
    Apple still want £500+ to go from 1GB to 4GB!?!?!?
    A couple of months ago when I started looking at getting an iMac Crucial wanted £180 for 4GB!!!!
  19. richard plumb
    richard plumb
    Jan 27, 2002
    14,519
    Windsor
    +1,054
    Hmm
    I upgraded my imac to 2GB when I bought it late last year. Can't remember but would that have been 1 extra 1GB stick, so I now have 2x1GB sticks?
    is that the same ram that the new macbooks use? If so I could buy 4GB for the imac where it'll count more (my main machine), and stick the 2x1GB sticks in the macbook?
  20. baldrick
    baldrick
    Dec 28, 2002
    3,370
    +246
    It would be quite easy to check but I would have thought that the 2 GB upgrade would have been 2 x 1GB. I believe it is the same RAM in both machines.
  21. istanbul05
    istanbul05
    May 21, 2006
    2,066
    Manchester
    +106
    Reduced to £52.63 now!!! :thumbsup:
    Just ordered some and i haven't even ordered my Macbook yet :D
  22. S2K DG
    S2K DG
    Nov 2, 2004
    265
    +18
    Don't forget your 7% back with quidco :smashin:
    Just ordered mine, need to get an imac now!
  23. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    Great heads up thanks!
    Just ordered 14GB worth :devil:
