Crt Wonabee!!
Discussion in 'Projectors, Screens & Video Processors' started by garyc, May 30, 2003.
  1. garyc
    garyc
    Dec 21, 2002
    887
    Jersey, Channel Islands
    +14
    I'm hoping to join you guys in the CRT world, but I know next to nothing about projectors!!!
    so apologies for the newbie questions:-
    I have a dvd player that can output a progressive signal (PAL/NTSC) should i be looking for a proj that can take this component prog signal direct or would I be better going through a line doubler ie. iscan or quadscan pro?
    Can anyone offer any idea of prices for 2nd hand seleco 400 or 500 (as example) and are the tubes expensive to get replaced OR what other proj should i be looking at?
    Do CRT's require a professional to set up?
    Sorry again for the novice questions
    Gary
  2. nathan_silly
    nathan_silly
    Good choice. Nicer PQ than all other display types!
    You need to find out whether or not your projector will accept progressive scan - I think 31.5khz horizontally.
    Tubes are quite expensive, at least £1000 each. However if the tubes have got a low mileage, say 500 hours or less then I see no problem. Just make sure it's had a service with a few months guarantee.
    If I remember correctly Seleco's have a white line at the top of the image, it's a bit distracting. They're OK PJ's, but there are better makes out there.
    Are you technically minded? If not then yes they need to be setup by an installer.
    However since I'm a cleaver sod I learnt within the space of a 2 hours how to setup one (with no experience before hand)~
    What is your budget?
    Check here and see what's available - try and get a newer PJ, rather than a run-down 5000+ hours with old worn out tubes.
    http://www.crtprojectors.co.uk/projectors.htm
    If you decide to install the PJ yourself- the easiest method is coffee table or behind-your back on a high chest of drawers type.
    When you switch it on- it'll look 3D effect like this..
    http://www.earthsci.gla.ac.uk/facil...age/image29.gif
    So what needs doing is angling the blue & red tubes (not the lenses) to align up with the green. Also the screen (electron gun hitting the crt) adjustment pot and lens (optical section) need to be adjusted to focus the grid equally up. Then you've got pincushion, trapezoid to correct. And if you're unlucky (takes some time) Schelmpluge - one side is more out of focus then the other. Then finally convergence - fine tuning the blue & red to match up exactly.
    Oh the gubbins of PJ's can kill (very high voltages) so be v. careful.
  3. Arthur.S
    Arthur.S
    Originally posted by nathan_silly [/i]
    There's a modification for this, costs about 100 squids.
    Just what kind of butcher are you? :D
  4. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,011
    3
    +7,728
    There should be nothing wrong with a machine that has a few thousand hours on the clock, as long as it has been run correctly and well installed. If you can chek the tubes then do so, and look for burn marks. My Barco cost me £600 has 6,000hrs on it, and very light burn, so light you cant see it. Best £600 i ever spent as I have had two years regualr use from it with no major hassles.
    Talk to Gordon or Roland on this site, they will give you great advice and can even help out with stock, install etc.
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Gary I'm not far from you in Reading come over an have look at what CRT can do, no presure honest.
    CRT's on some of the big projectors can run as high as £100 but on a Seleco recon more like £300.
    Run time on a projector over a year to two years old is irelevant ignore it, tube condition is king. It is possible with miss use to ruin a set of tubes in 48hrs
    Also a projector that has stood idol for long peroids will be far less relaible than one that been worked. I would expect to see at least a 1000 hours for every year for a noice reliable machine. Most CRT's will run for about 20-30,000 hours before major components start to go but far less if they have long periods of shelf time.
  6. Arthur.S
    Arthur.S
    As they say in the car trade Roland; "If a car has a 'silly' low milage on it....why has it?"
  7. garyc
    garyc
    Dec 21, 2002
    887
    +14
    Thanx Guys for all your advise.
    Roland - I would like to take u up on your offer of a little "no pressure " demo if thats still ok?
    Please Pm me details to arrange or email (you should have my email from a few days ago)
    cheers
    Gary
  8. voodooflux
    voodooflux
    Nov 2, 2002
    267
    Redditch, UK
    +12
    Roland - as someone else about to enter the world of CRT I'd also be interested in a demo. Feel free to drop me a PM.
    v.f.
  9. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,426
    Norfolk
    +168
    I am selling a Sim2 SVD500 if you're interested.
    Set up by Chris Frost no less.
    Ad on classifieds forum.;)
  10. garyc
    garyc
    Dec 21, 2002
    887
    +14
    Edgeyboy - thanks for the heads up on your sim2 crt sale, sorry but its a little outside my price bracket, but good luck with your sale.
    cheer
    Gary
