CRT vs Rear Projection CRT
Discussion in 'General TV Discussions Forum' started by Bluelaser, Dec 14, 2003.
  1. Bluelaser
    Bluelaser
    Hi all :)
    I am just wondering what the difference is between CRT tv's and CRT Rear Projection Tv's in the following ways:
    - Sharpness of Picture
    - Vibrance of Colours
    - Richness + Range of Colours
    - Overall Quality of picture
    - Reality of Picture
    - Brightness of Picture
    - (Anything else relivant, Viewing angle etc...)
    Say for example a 36" Crt vs a 42"/44" Crt rear projection.
  2. Bluelaser
    Bluelaser
    Anybody?
  3. Gillious
    Gillious
    Oct 28, 2003
    45
    That's kinda like trying to compare a bus to a car without saying which make/size of car, or make of which bus.
    In general, the very best PRTV's fall just short on PQ from the very best direct view CRT's. Just bear in mind as the image gets bigger it also degrades.
    This said a well setup 42" PRTV can put a 36" direct view to shame. From my experience bigger DV set's seem to have issue with geometry that can't be corrected in the same way that most PRTV's let you.
    To answer part of your question more directly, direct view CRT’s have a much better viewing angle than RPTV’s however unless you levitate whilst watching TV it won’t really cause you any problems.
  4. Bluelaser
    Bluelaser
    Thanks. For standard digital tv channels on sky, what is the biggest tv you recommend, bearing in mind I receive 100% quality and 100% signal strength on a 1.1m dish:
    (Not to show noticable pixelisation, distortions etc.?
  5. Gillious
    Gillious
    Oct 28, 2003
    45
    Well, it differs between each channel. You will find the like of sky movies scale up much better than channels like flaunt, magic etc.
    on my 42" RPTV I can see some nasties on the later. All the main channels, BBC, ITV, Sky etc look fantastic. This said, those that are not so good are still fully watchable
