CRT vs LCD in terms of TRUE diagonal size?
Discussion in 'LCD & LED LCD TVs' started by akerman, Nov 24, 2004.
  1. akerman
    akerman
    Hey. I've been wanting to ask this question here for a while, but couldn't be bothered to make an account. Then I found out that I already had an account, that I made last year :cool:
    Anyway here goes:
    It's a well-known fact, that a 19" CRT computer monitor only has a viewable area of 18" in most cases. We also know that an 19" LCD computer monitor, has a viewable area of just that - 19".
    BUT - is it the same with televisions? Because I'm considering a 32" CRT or a 32" LCD - if the 32" CRT really only is 30" in actual size, then that would certainly make a difference to me.... is this the case?
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    I've just replied to you on another thread! Anyway, yes, you've got it! LCD's measure what they say. A 32" LCD is 32" inches across etc. and yes, a 32" CRT is (slightly less than) 30" across. A CRT measurement refers to the size of the tube, some of which is obscured behind the TV frame allowing us to see less than the suggested measurement. Simple really.
  3. Skiny
    Skiny
    Aug 18, 2004
    278
    16
    Yea, LCDs usually are the correct size, although not always. Most of the time a CRT will have 2" - 2.5" missing off of the viewable size.
    To be sure, check the size of the display in CM. If it says 81cm, then it will be 81cm viewable.
  4. uczmeg
    uczmeg
    May 18, 2003
    3,151
    71
    Nottingham
    +45
    My 36" CRT measures about 33" !!
    A 37" LCD (sadly not mine) against it looks massive...
  5. CLH
    CLH
    Apr 15, 2002
    2,126
    38
    +21
    This is why I plumped for a 32" to replace my 36" CRT.
    Very similar size all things considered.
    Especially since I've been coping with a 28" CRT in the interim which actually seems quite big at the moment!!!
  6. akerman
    akerman
    Thanks guys.. I think that nailed it - I want a 32" lcd :/
