CRT Tuning
Discussion in 'Projectors, Screens & Video Processors' started by schmidtsm, Oct 27, 2005.
  1. schmidtsm
    schmidtsm
    Hello,
    I have tuned my CRT NEC 6100 via Avai dvd. When I watch a dvd the picture looks great. When I watch hdtv cable it looks very grainy and ther are wavey lines like the contrast is set too high. I am running everything through a Maxx 100 or Focus Centerstage 1 scaler set at 720P.
    Do I need to change inputs on the scaler and tune each input with the dvd. I am running progressive composite for the cabel tv and interlaced for the dvd. So you would think that the cable would have a better picture.
    I hope you guys can help me figure out where the problem is.
    Schmidtsm
  2. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    A bit more information would be helpful.
    I can't quite see why wavy lines and grain should correlate with high contrast.
    And I guess you mean progressive component?
    I use a CS-1, and find that the output settings are independent of the inputs (given sources set at the same level). i.e if I set up on say s-video b, then component a is fine.
    Generally, black levels creep up and down between dvds and broadcast stations.
  3. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    The wavey lines?
    describe them please.
    Horizontal, vertical, on the diagonal. move up down left right stay staionary but appear to wave.......
    How do they effect the picture - colour or brighness change etc.
